04-21-2016 01:17 PM - edited 07-05-2021 04:55 AM
Good afternoon,
Is it possible to configure a Captive Portal, that redirects all the wireless clients to a Data Base updated daily by the client and creates a unique username and password?
This is the scenario:
The client has customers with a ticket number associated, in a data base that changes everyday. They want to give Wireless access only to their customers, so they requested that the customers information creates dynamically a username and password. Is it possible to do it with a Captive Portal that redirects the clients to the Data Base and create a user and password?
On the other hand, how many users can I create locally in a 2504 WLC?
Thanks in advance,
Solved! Go to Solution.
04-21-2016 08:09 PM
I think you would be better off creating a custom portal on your own web server. There are examples where you download the 2504 software in the web authentication bundle.
04-21-2016 08:09 PM
