Wireless AP configuration in Autonomous Modes
amh4y0001
Level 3
Level 3
I have Cisco Aironet 2700 series AP that I have converted from LWAP to Autonomous.
Can someone direct me an to-the-point article or steps how to configure it (official documentation is too much and you are almost lost to find the correct configurations).
You can use these tool:
1. Ekahau
2. Airmagnet
May be you can a hire a site survey engineer and he will do it for you :)
Reagrds
Don't forget to rate helpful posts
11 Replies 11
Sandeep Choudhary
Check these posts:
https://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
https://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
https://mrncciew.com/category/autonomous-ap-config/
https://mrncciew.com/2012/10/24/multiple-ssid-config-on-autonomous-ap/
Are we not supposed to connect the Internet line from Wireless Router to the AP?
I have an existing Wireless Router from ASUS and there is SSID configured called MyWLAN.
Shall we use the same SSID when configuring the AP?
Shall AP and wireless router be use simulteniously or AP will replace wRouter?
The documentation you mentioned did not provide this information.
No, you cannot replace your wireless modem as it does the NAT,DHCP etc for your clients. Cisco AP can't do the NAT function & directly plug to an internet connection.
So what you can do is when you get wireless working with Cisco AP, you can disable wireless functionality of your wireless router, but other functionality to be remain.
Yes.
Both require. As said earlier, you can turn off wireless on your wireless router once Cisco AP is working properly.
Rasika
*** Pls rate all useful responses ***
I have two options on my Wireless Router:
1. Enable WLAN
2. Enable Interface
Which one to be used?
Thanks for reply,
I have some questions that I am wondering still...
With the helpf of following video, I configure the AP.
https://www.youtube.com/watch?v=5RE55VBsyDE
If I do exactly what is mentioned in this video, I am able to configure AP. On some client Machines AP is available while other can not find that newly created SSID (even I have selected broadcast).
1. Why is like some machines can not reach / find the new SSID (all machine are near by each other).
2. How to deal with frequencies or range or is it something will be corrected automatically by AP?
3. Shall I enable Dot11Radio0 or Dot11Radio1?
4. 2.4 0r 5Ghz ?
5. IP should be DHCP enabled or static one  OR belongs to same subnet as wireless router?
Try to enable both band (2.4 and 5 Ghz), may be few machine only works with one band.
If you enable both band then AP will automatically do the rest....Make usre Antenna is connected properly.
Yes
4. 2.4 0r 5Ghz ?
Enable both
Leave it to DHCP
Thanks a lot Sandeep for reply. Just a bit confusion here:
I have 3 APs which are supposed to be used to extend the WiFi range ,,, I am talking how I can determine which Place AP should be installed? I mean how to know that in this particular area, there is need for Another AP.
Site survey is the best  idea to determine the exact location of placement for AP.
1. Do you recomend some toos for this? Or or lets say If I have 3 APs, one in middle and one on each side_?
2. On 5 GHz client, I still get 130 MB link instead of 1 GB .... something is wrong here? AP and client both support 5 Ghz.
1. Ekahau
2. Airmagnet
Reagrds
Thanks, you solved it !
