Nexus 7K full mesh to WAN Router interoperability
zheepingliew
Hi Ladies and Gentleman,
I'm going to deploy a pair of Nexus 7K and have a full mesh connectivity to two WAN Router as below.
I had prepared the configuration between Nexus and WAN switch but not sure whether this will work or not. Can help to comment? Thanks
WANSW1 WANSW2
interface Vlan10 interface Vlan20
 ip address 10.10.10.13 255.255.255.252  ip address 10.10.10.17 255.255.255.252
 ip ospf authentication message-digest  ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 7 12345  ip ospf message-digest-key 1 md5 7 12345
 ip ospf network point-to-point  ip ospf network point-to-point
 ip ospf hello-interval 5  ip ospf hello-interval 5
interface Port-channel100 interface Port-channel200
 description To Nexus  description To Nexus
 switchport trunk encapsulation dot1q  switchport trunk encapsulation dot1q
 switchport mode trunk  switchport mode trunk
interface GigabitEthernet1/3 interface GigabitEthernet1/3
 channel-group 100 mode on  channel-group 200 mode on
interface GigabitEthernet1/4 interface GigabitEthernet1/4
router ospf 1 router ospf 1
 log-adjacency-changes  log-adjacency-changes
 redistribute static subnets  redistribute static subnets
 passive-interface default  passive-interface default
 no passive-interface Vlan100  no passive-interface Vlan200
 no passive-interface GigabitEthernet1/2  no passive-interface GigabitEthernet1/2
 network 10.10.10.9 0.0.0.0 area 0  network 10.10.10.10 0.0.0.0 area 0
 network 10.1010.13 0.0.0.0 area 0  network 10.10.10.17 0.0.0.0 area 0
 default-information originate  default-information originate
N7K-1 N7K-2
vlan 5,6,10,20 vlan 5,6,10,20
  no ip redirects   no ip redirects
  ip address 10.10.10.14/30   ip address 10.10.10.18/30
  ip ospf message-digest-key 1 md5 3 12345   ip ospf message-digest-key 1 md5 3 12345
  no ip ospf passive-interface   no ip ospf passive-interface
  ip router ospf 1 area 0.0.0.0   ip router ospf 1 area 0.0.0.0
  description WANSW   description WANSW
  no shutdown   no shutdown
interface port-channel100 interface port-channel100
  description Port-Channel Link To WANSW   description Port-Channel Link To WANSW
  switchport   switchport
  spanning-tree port type normal   spanning-tree port type normal
  vpc 100   vpc 100
interface port-channel200 interface port-channel200
  vpc 200   vpc 200
interface port-channel500 interface port-channel500
  description vPC L2Peer-Link to N7K2   description vPC L2Peer-Link to N7K1
  switchport trunk allowed vlan 5,6   switchport trunk allowed vlan 5,6
  spanning-tree port type network   spanning-tree port type network
  vpc peer-link   vpc peer-link
interface port-channel800 interface port-channel800
  description  L3Peerlinks to N7K2   description  L3Peerlinks to N7K1
  switchport trunk allowed vlan 10,20   switchport trunk allowed vlan 10,20
interface Ethernet1/1 interface Ethernet1/1
  description  Po100 to WANSW   description  Po100 to WANSW
  channel-group 100 mode on   channel-group 100 mode on
interface Ethernet1/2 interface Ethernet1/2
  description  Po200 to WANSW   description  Po200 to WANSW
  channel-group 200 mode on   channel-group 200 mode on
interface Ethernet1/23 interface Ethernet1/23
  description  L3Peerlinks to N7K2   description  L3Peerlinks to N7K2
  channel-group 800   channel-group 800
interface Ethernet1/24 interface Ethernet1/24
interface Ethernet1/45 interface Ethernet1/45
  description "vPC L2Peer-Link to N7K2"   description "vPC L2Peer-Link to N7K2"
  channel-group 500   channel-group 500
interface Ethernet1/46 interface Ethernet1/46
Reza Sharifi
The design and configuration should work fine. A couple of notes:
1-I am not sure what type of switches are your WANSW1 and 2 are. Just make sure you have the right license to run routing protocols specialty if you are planning to run BGP with the providers.
2-What device will do the NAT for you or you don't need to run NAT at all?
3-Since you have switches facing the Internet providers, you may want to think about putting a set of firewalls between WANSW1, 2 and the Nexus for security unless you are planning to do that with the switches.
Thanks for the advise.
1. Both WANSW are existing running switches so the license is not an issue.
2. I dont do NAT at all because the interface that faced ISP is a DWDM link so it still internal IP.
3. ISP provided DWDM and not Internet Service so it is still ok for time being.
I have some concerns with the design and configuration.
Lets say the HSRP master for Vlan5 is N7K01, will it still utilize E1/1 and E1/2 to reach the WANSW or only E1/1? becasue E1/2 is connected to WANSW2 which is Vlan20.
In the event of N7K01 fails, will both E1/1 and E1/2 of N7K2 be utilize?
This should be tested, but if you are going to use OSPF between the Nexus and the WAN switches without any cost changes and since the links are equal cost, OSPF will load balance the traffic between e1/1 and e1/2. You can always modify the cost on one of the links so it is always used as backup.
If the destination costs adds up to be the same for both links than the traffic will be load balanced.
