04-24-2016 12:19 AM - edited 07-05-2021 04:56 AM
we have a setup for wireless as below:
1) 13 AP 1602i
2) WLC 2504 IOS image updated to version AIR-CT2500-K9-8-0-121-0
we reconfigure the WLC from scratch and configure LAG feature with 2G interface on switch.
but the Clients still experience slow data speeds, where the internet speed after testing it reach max 8-12Mbps. also i disabled all the AP's and keep only one access point connected with one user. the same issue still available.
is there any suggestion to fix the problem ??? i appreciate your help
04-24-2016 12:22 AM
Are you using 40Mhz wide channels?
04-24-2016 12:25 AM
Under Wireless/802.11a/DCA (set channel width to 40Mhz).
You could also try turning off the 2.4Ghz spectrum if it is not being used, to force clients onto the faster 5Ghz spectrum.
04-24-2016 07:11 AM
What client are you using to test with ? Intel has UAPSD comparability issues. If enabled the client doesn't perform to full potential.
04-24-2016 06:28 AM
Hi,I see you have done a config from scratch and I assume you've just added the WLANs and haven't touch any of the other settings.I might just try doing a throughput test internally from WLAN to Wired,perhaps using
