04-24-2016 02:06 PM - edited 03-05-2019 03:52 AM
Hi, I notice there are two ip address which are connected with in two separate devices. I am not sure it can work. Any one explain it? Thank you
One ip address is 10.10.10.196/31, and another is 10.10.10.197/31
I guess the network ip already become host ip address
04-24-2016 02:26 PM
As long as you are running modern Cisco code that will be fine. /31's are used to reduce IP wastage.
04-24-2016 02:32 PM
Thank you for your reply. How about broadcast address? Can you explain "modern CIsco code" used here?
04-24-2016 06:58 PM
Since /31 is used for point to point links you only need 2 IPs an so there is no need for broadcast address. "Modern Cisco codes" means newer IOS version.
04-24-2016 08:22 PM
Thank you Reza
What version is new version? Using the following version is also Ok
Router#sh ver
Cisco IOS Software, 3600 Software (C3640-TELCO-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Sat 18-Sep-04 14:32 by eaarmas
ROM: ROMMON Emulation Microcode
ROM: 3600 Software (C3640-TELCO-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
