SNMPv3 not working on Cisco 5672 with Cisco Prime 3.0
Swenson21
I cannot get any of my Cisco 5672UP switches to respond to Prime 3.0 over snmpv3.  I keep getting Partial Collection Failure.  Does anyone have the complete configuration for both the prime side and switch side, so I can compare.
I am running 7.0(8)N1(1) on my switches.
Thanks for any assistance you can provide.
alois.heilmaier
Not sure about if snmp is the problem.
afaik with my WLC5500 I also had problems to collect the configuration via PI.
I needed to set the ssh timeout from default 60s to ~240s. (snmp timeout is still default 10s)
https://supportforums.cisco.com/discussion/13046011/template-deployment-bug-prime-infrastructure-310
-> difficult to find the configuration: see last entry from powys
