04-25-2016 12:40 PM - edited 07-05-2021 04:57 AM
Is it possible to convert the access point AIR-CAP3702I-A-K9 to autonomous, and in case it is, how do I convert it?
Thank you
04-25-2016 01:00 PM
Read THIS.
04-25-2016 01:10 PM
Thank you for your short response Leo.
The problem is that I tried to do it with a TFTP server but wasnt able to establish connection between my pc and the AP.
I've converted APs before, but never an air-CAP3702i-a-k9.
I will try to convert but havent been succesful so far.
Thanks again
04-25-2016 01:46 PM
What error messages are you getting? Is the PC firewall turned off?
04-26-2016 06:43 AM
The firewall is off.
I'm using 3CDaemon and the message that I get is that it cant open the file.
I tried using the following filenames: ap3g2-k9w7-tar.default and ap3g2-k9w7-tar.153-3.JC by CLI in the WLC.
Do you know what can I be doing wrong or another walkaround for this issue?
04-26-2016 11:15 AM
Are you sure this is the error message?
Run the entire proceedure again and post the entire process. I want to see everything, including the error message.
04-26-2016 11:46 AM
Attached is the capture in the TFTP Server.
I then tried the second method (Using MODE Button and TFTP Server) and still couldnt do it. In this case, the problem was the following:
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 68 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 20953600
flashfs[0]: Bytes available: 20205056
flashfs[0]: flashfs fsck took 11 seconds.
Base Ethernet MAC address: 00:42:68:18:22:30
Ethernet speed is 1000 Mb - FULL Duplex
button is pressed, wait for button to be released...
button pressed for 24 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g2-k9w7-tar.default
examining image...
DPAA Set for Independent Mode
tide_boot_speed = 1000
DPAA_INIT = 0x0
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (permission denied)ap:
What do you think that can be wrong?
04-26-2016 12:30 PM
permission denied
"permission denied". That says a lot. Check the "permission" of the file.
If not, try using another computer to be the TFTP server.
04-26-2016 01:18 PM
Do you think the problem is the TFTP Server or the computer?
Thank you
04-27-2016 01:17 AM
I am suspecting the computer is the problem.
