04-25-2016 01:31 PM - edited 03-17-2019 06:42 AM
I would like to enter caller input for a department list of up to 11. How is this possible if the caller input goes up to 9?
04-25-2016 01:37 PM
It's not possible, you'd need to use 2 call handlers to do that, or shorten that list for just 1-9 options
04-26-2016 07:41 AM
Hi there,
Like Java nicely noted (+5) this is where you have to get a bit creative when building call trees that require more than 9 caller input options. What I have done in the past was to split the options into multiple groups like;
"Thanks for calling Acme tools sales department"
For agents with last names beginning with A to M - press 1 (routes to call handler 1)
For agents with last names beginning with N to Z - press 2 (routes to call handler 2)
The nice thing about this is when somebody leaves the group at least the re-recording of the greetings only takes half the time :) and callers don't have to listen to such a long list of names which enhances the overall customer experience!
Cheers!
Rob
