Cisco 2960X-48LPS-L crash
guest-user-test
Hello
After the OS update, the following message appears at startup switch .  guide me please. Thanks
6 Replies 6
Leo Laohoo
switch: boot c2960x-universalk9-mz.152-3.E1.bin
This command is invalid because the filename is NOT found in the root directory.
Can you post the output to the command "dir flash:c2960x-universalk9-mz.152-3.E1"?
Try a different IOS version.
thank for help
but
i download c2960x-universalk9-tar.152-4.E1.tar from Cisco Site
Next Checksum MD5 And SHA512 In the cisco Site With Application is ok
Next formated the flash cisco Switch
Next Copy c2960x-universalk9-tar.152-4.E1.tar To USB Flash
Next Use Command  Archive Download-sw /Overwite Usbflash01:/c2960x-universalk9-tar.152-4.E1.tar
The Tar File Extract And setup In Switch But After Boot This Fail Is Show
Thanks for help me
Try a different IOS other than 15.2(4)E1.  Could be an IOS fault.
IF there is a stacking module attacked, remove it and try rebooting it again.
not any stacking module attacked
switch its new and do not working
i try with other os details:
15.2(4)E1       boot fail
15.2(3)E3       good boot     no problem
15.2(2)E4       good boot     no problem   ( Suggested Cisco)
Raise a Cisco TAC Case so TAC can determine the cause of the potential software bug.
