Authenticating Cisco IP Phones using ISE and 802.1X
Bobby Stojceski
I have seen a few others ask similar questions but no answers seem to have been posted.
How do you configure ISE 2.0 to authenticate a Cisco IP Phone that has the MIC and LSC certificates installed? I have already done the export of certificates from CUCM and import into ISE, but I just cannot get the Authentication Rule/s right. The phone is enabled for 802.1X and certificate, and switch is doing it's job as I see the RADIUS logs both in ISE and the switch showing the failures.
What identity store does a Cisco IP Phone use to authenticate itself against in ISE? Surely every phone doesn't need to be added into ISE ahead of time (hundreds or thousands)? The failure I get is ISE unable to match the user in any identity store.
There doesn't seem to be any guides available to help here other than old ACS guides.
I see there are prebuilt Authorization rules in ISE for Cisco IP Phones but I can't get far enough for the device to authenticate let alone hit the Authorization rule.
Can anyone help?
Thank you.
jan.nielsen
Level 7
Level 7
If you are using EAP-TLS, your authentication rules, need to select a certificate profile and an identity store, for EAP-TLS it will use the cert profile for auhthentication. It will still try to get AD groups for the CN/SAN name of your MIC/LSC cert, but it shouldn't fail authentication.
This thread also has some info :
https://supportforums.cisco.com/discussion/10952961/8021x-phone-authentication-eap-tls-mic-only
