04-27-2016 08:08 AM - edited 03-01-2019 08:15 AM
1) How are the devices identified which are VSS and VPC enabled in a datacenter network?Please explain elaborately with examples.
2)Can vpc be enabled across all nexus platforms?
Solved! Go to Solution.
04-28-2016 01:05 AM
For the first query there are a couple of helpful posts
https://supportforums.cisco.com/discussion/12367366/vss-vs-stackwise-vs-vpc
https://supportforums.cisco.com/discussion/12502831/what-functional-difference-between-vss-and-vpc-nexus
Regarding the second query, vPC can be enabled across all major Nexus platforms like 5000, 7000, 9000 series. You can reference the config guides for the specific models like the one below
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Manish
04-28-2016 01:05 AM
Manish
