Warning message
mra
Apr 30th, 2016
Hi all,
I have deployed MRA single interface. In the internal corporate I am getting full audio features, perfect. While using MRA I cannot hear audio and ring back as well. I am using CUCM 11, 8.7.2 C&E.
All ports in firewall are open for test purpose and NAT reflection is correctly configured.
Certificates are uploaded correctly.
Shabeer
Suresh Hudda Sun, 05/01/2016 - 09:57
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Is it single NIC deployment model with NAT enabled ? If yes, pls confirm below settings.
> Exp C is pointing to public IP address or FQDN of Exp E ?
> If pointing to the FQDN of Exp E for TLS, verify the FQDN must resolve to the Public IP
Address of Exp E (for this you need to have a A record in enterprise DNS for it).
If above settings are fine then it must be a network problem, if you can attach diagnostics logs of both C & E with tcp dump enabled then it can be confirmed.
Suresh
