Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928861members
1242722discussions
Community Activity
Failover according to Meraki MX WAN LOSS threshold
Hello. We're currently running Meraki, and there is an issue we found. As far as I know, MX failover is automatically activated when the WAN is disconnected. If WAN Loss reaches a certain threshold, can't you force failover to Unit 2?  Thank you.
Translator by Community Manager
  • 28 Views
  • 0 replies
Licenses APIについて
パートナー権限にて、複数のorgに対して以下のLicenses APIを実行したところ、403エラーが返却されました。https://webexapis.com/v1/licenses 以下サイトの「How to Update Your Managed Partner List」を参照し、一度Control HubにログインもしくはGET /organizations/{id} のAPIを実行したところ、一部のorgについてLicenses APIにて情報取得できたものの、他のorgについては解...
ccsn by Level 1
  • 10 Views
  • 0 replies
Serial Interface Configuration Help with C8300
Hello I am currently having trouble translating a configuration on a serial interface from a C3900-SPE150 to  a C8300-1N1S-6TThe current configuration on the C3900 on  the serial interface is as follows:ip address X.X.X.X 255.255.255.252encapsulation...
Extended ACL inbound and outbound
Good morning friends,I have created two extended ACLs for in and out of my int vlan and applied it under int vlan for both directions inbound and outbound. I have created ACLs entries like this.For int vlan no. Out1 permit ip 10.1.0.0 0.0.255.255 hos...
Simple nat config refuses to work on Cisco ASR 1001 ???
I have simple nat config which I need to use:ip nat pool test 40.0.0.3 40.0.0.3 netmask 255.255.255.0ip nat inside source list 1 interface GigabitEthernet0/0/1 overloadip nat inside source list 2 pool test overloadaccess-list 1 permit 10.0.0.0 0.0.25...
Vyncy by Level 1
  • 36 Views
  • 0 replies
Configure Port-channel and vPC in advance in Nexus 9K
hi,i'll be configuring a new N9K switch to replace a C9300.my question is, can i configure in advance the port-channel and vPC in the N9K even without the SFP inserted and fiber cables patched?just want to prepare the config so it will be a faster to...
UCSMにおけるPassword Encryption Keyについて
はじめにPassword Encryption Keyについて発生するエラーと解消法バックアップのタイミングの調整Password Encryption Keyの設定と文字制限参考情報 はじめに 本ドキュメントでは、Cisco UCS Manager release 4.2(3d)から導入された「Password Encryption Key」の概要と「Password Encryption Key」を設定しない場合に生じるエラーの解消法、設定の方法について説明します。 Password E...
daiogawa by Cisco Employee
  • 48 Views
  • 0 replies
IOS XE on Cat8kv AlwaysOn
I'm not able to ssh to devnetsandboxiosxe.cisco.com. I'm using the following command in Linux ssh admin@devnetsandboxiosxe.cisco.com. The response is...kex_exchange_identification: Connection closed by the remote hostConnection closed by 131.226.217....
Extremely slow and poor overall WiFi quality with C9130AXI
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
NexCyb by Level 1
  • 65 Views
  • 1 replies
