05-02-2016 04:05 AM
I have recently installed CPI 3.1. I can't seem to find VUDI information anywhere. This is required to migrate license from version 2.1. Secondly can't see the option to enable compliance under Server setting and hence can't get EOX reports.
Any help appreciated.
Solved! Go to Solution.
05-02-2016 07:21 AM
From the cli, "show inv" or "show udi" should give you the VUDI.
When you built the VM did you use the Professional size VM? As noted in the Quick Start Guide:
Compliance is supported on the Professional virtual appliance (OVA) and the Gen 2, UCS-based physical appliance only.
05-02-2016 07:21 AM
06-01-2016 10:44 PM
