05-03-2016 07:13 AM - edited 03-12-2019 12:41 AM
All,
I have a quick question which is a source of discussions at the office. I contend that when VLAN information is sent through a Site to Site Connection and is natted, there is no need for the other end to have the same vlan information on firewall. Am I correct? If not why?
05-03-2016 07:31 AM
Hi James,
From VLAN
As a thumb rule for VPN both the sides should not have overlapping subnets.
To overcome this we usually NAT the real traffic at one end to a different IP/subnet.
Here is the config example:
https://supportforums.cisco.com/document/51491/asa-bi-directional-overlapping-nat-example-configuration
Aditya
Please rate helpful posts.
05-03-2016 08:43 AM
The document is a good answer to that question but I need more clarity. So if I nat everything through the Site to Site tunnel. An IP address from a ISP connection would work. That brings me back to my initial question. Since I have this ISP with a different IP. Do I need to send my VLAN information to the Core Router.
05-04-2016 12:05 PM
Hi James,
Could you please elaborate your requirement and give some example to explain the problem you want to discuss.
It would help in suggsting apt solution.
RS
05-04-2016 04:11 PM
05-09-2016 04:55 AM
I guess my real question is with me using this base configuration at many sites will it cause a routing loop? since i will be sourcing the VLAN (250) from the FW and from the remote router! will the tunnel not see the ip address of the VLAN 250?
