05-03-2016 05:31 PM - edited 03-08-2019 05:36 AM
With respect to the following:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus69731
One of the affected releases include 15.1(2)SG and the fix is to upgrade to 15.1(2)SG6. We have switches running IOS-XE ver 03.04.01.SG such as the following.
Core#sh ver | i Soft|bootfl
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.01.SG RELEASE SOFTWARE (fc3)
System image file is "bootflash:/cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin
Is this version affected or is 03.04.01.SG totally different from those listed as affected in the link?
Thanks in advance.
Solved! Go to Solution.
05-05-2016 12:29 AM
Yes it looks to be as if you go to the download page the 151-2.SG1 is just 3.4.1SG(ED) which is on the release as effected , so 15.1-2SG1 is 15.1-2SG
https://software.cisco.com/download/release.html?mdfid=283289791&softwareid=282046477&release=3.4.1SG&relind=AVAILABLE&rellifecycle=ED&reltype=latest
ED early deployments can be more susceptible to bugs than MDs main deployments because there not as thoroughly tested
05-04-2016 01:27 AM
No the first bit is the IOS-XE 03.04.01 (release number ) bit and the 15.1-2 is the IOSd section that allows you to correlate with actual older ios versions, your effected by that bug unfortunately going by the list
The SG6 is a better image its an MD the one you are currently on is ED
05-04-2016 05:19 PM
Thanks for the response Mark. So just to clarify, my switch is indeed affected?
05-05-2016 12:29 AM
05-05-2016 01:56 AM
Alrighty then. Thanks Mark.
