05-04-2016 05:21 AM - edited 03-10-2019 11:44 PM
Hi All,
I am using guest access services using self-registration.
When my account gets expired and i try login in to the guest portal i should get the message saying the account is expired. can i modify the messages.
Any help would be appreciated!!!
Laxmi K
05-04-2016 02:55 PM
Hi there, have you tried modifying the guest portal "Error" page?
Thank you for rating helpful posts!
05-05-2016 05:48 AM
Hi Neno,
thanks for your reply.
Yes, i tried modifying the guest Error Page against "Message Key" ui_login_failed_error and Message Text "Account expired"
But this wont work as it give same error message even if i type incorrect username or password.
I wanted to know against which message key i do need to modify for account expire.
Laxmi
05-09-2016 08:32 PM
Any suggestion on the post pls.
