05-04-2016 07:46 AM - edited 03-17-2019 06:05 PM
Hi, I am hitting this error installing Jabber for Windows onto a Windows 7 Enterprise PC. I have tried Jabber v11.6 and previous versions but I get the same error so it must be a local PC or permissions issue. Any thoughts on how to work around the issue?
MSI (s) (3C:94) [14:29:54:362]: Executing op: FolderCreate(Folder=C:\ProgramData\Application Data\,Foreign=0,,)
CreateFolders: Folder: C:\ProgramData\Application Data\
MSI (s) (3C:94) [14:29:54:362]: Note: 1: 1326 2: 5 3: C:\ProgramData\Application Data\
MSI (c) (38:FC) [14:29:59:657]: Doing action: setErrorUnknownError
Action 14:29:59: setErrorUnknownError.
Action start 14:29:59: setErrorUnknownError.
MSI (c) (38:FC) [14:29:59:657]: PROPERTY CHANGE: Modifying ERROR_INSTALL property. Its current value is '0'. Its new value: '4'.
Action ended 14:29:59: setErrorUnknownError. Return value 1.
Error 1326. Error getting file security: C:\ProgramData\Application Data\ GetLastError: 5
MSI (s) (3C:94) [14:29:59:657]: Product: Cisco Jabber -- Error 1326. Error getting file security: C:\ProgramData\Application Data\ GetLastError: 5
10-14-2016 09:10 AM
Not sure if you still have this problem but for anyone else that does, I had to log in as the local admin and give permissions for the local "users" group to the C:\Programdata\Application Data directory. Once I did that the install completed successfully.
02-10-2017 03:20 PM
I can confirm that Ken.Head@chkd.org method worked for me.
I had same the error and after I followed that procedure I was able to install Jabber sucesfully
Thanks Ken!
La acción se inició a las 17:04:22: setErrorUnknownError.
MSI (c) (64:BC) [17:04:22:789]: PROPERTY CHANGE: Modifying ERROR_INSTALL property. Its current value is '0'. Its new value: '4'.
La acción terminó a las 17:04:22: setErrorUnknownError. Valor devuelto: 1.
Error 1326. Error al obtener la seguridad del archivo: C:\ProgramData\Application Data\. GetLastError: 5.
MSI (s) (9C:74) [17:04:22:789]: Transforming table Error.
MSI (s) (9C:74) [17:04:22:789]: Producto: Cisco Jabber -- Error 1326. Error al obtener la seguridad del archivo: C:\ProgramData\Application Data\. GetLastError: 5.
La acción terminó a las 17:04:22: InstallFinalize. Valor devuelto: 3.
Jabber version 11.7 "CiscoJabber-Install-ffr.11-7-1"
Windows 7 Ultimate SP1 x64
03-04-2018 11:42 PM
In this case I would recommend to try LongPathTool
