05-04-2016 08:42 AM
Is there a way to tell WAAS to no longer optimize sessions that have an excessively long open duration? We are running 5.5.5 and often have sessions for either email or CIFS that may have been open for days on end. Is there a way to put a time limit on those sessions? Our client is bumping up against the connection limit occasionally and eliminating those long-lived sessions would reduce the "noise floor" if you will and reduce the number of overall connections. I realize there is also a user training aspect to this issue but we also realize that not everyone is going to shut down their email or open windows to file shares when they are done for the day. Thanks!
05-04-2016 09:41 AM
Hi Tyler,
This doc probably would be helpful to customize the timeout values:
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v551/reference/cmdr/glob_cfg.html
To configure TCP parameters on a WAAS device, use the tcp global configuration command. To disable TCP parameters, use the no form of this command.
tcp {cwnd-base segments | ecn enable | increase-xmit-timer-value value |
init-ss-threshold value | keepalive-probe-cnt count | keepalive-probe-interval seconds |
keepalive-timeout seconds}
no tcp {cwnd-base segments | ecn enable | increase-xmit-timer-value value |
tcp increase-xmit-timer-value: 1
tcp init-ss-threshold: 2 segments
Hope this helps.
Alex
05-25-2016 05:28 AM
Hello
Did you find a solution for this problem?
If yes, please provide the solution for me.
05-25-2016 06:57 AM
Unfortunately, no. But to some extent it makes sense why you might not want WAAS to have that capability. It's a bit too intrusive. Since posting this we have determined that most of these really come down to poor user behavior which is manageable with training. Outside of that you just have to find ways of managing the total connections to prevent exceeding the max threshold. One of the things we did in this customer is flip the WCCP ACL on it's head. Instead of using the ACL to deny certain protocols and allow all other TCP traffic we spent time identifying what really needed to be optimized or what truly got the benefit from it and only allowed those TCP ports and denied all others. That has brought the total connections under better control.
