05-05-2016 10:56 AM - edited 03-08-2019 05:38 AM
I hope you are all well!
I try to configure HSRP in cisco catalyst 3850-X series switch, But I can't configure HSRP cause the command are not there.
This is the Software version installed on it...
Switch Ports Model SW Version SW Image Mode
1 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
So please anybody help me how to configure HSRP.
Thanks & Regrads
Fozla Rabbi
05-05-2016 12:34 PM
What is the output of "sh ver"?
Also, under the vlan interface where you are trying to configure HSRP, what is the output of "standby ?"
example:
config t
inter vlan 1
standby ?
05-05-2016 12:42 PM
Hi!
HSRP in 3850 is supported till version 3.3.X so an update is necessary to any other version, 3.6.4 recommended. Also, at least IPBASE license is needed.
Refer to the following cisco official document for details:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/ip/configuration_guide/b_fhrp_3se_3850_cg/b_fhrp_3se_3850_cg_chapter_010.html
Hope it helps, best regards!
JC
05-09-2016 09:16 PM
Hi!
Please help me how to IOS Update 03.02.03.SE cat3k_caa-universalk9 to cat3k_caa-universalk9.SPA.03.06.04.E.152-2.E4.bin.
Please send me Procedure of IOS up-gradation.
Thanks & Regards
Fozlarabbi
05-10-2016 05:38 AM
Start looking at this section of the config guide.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/consolidated_guide/configuration_guide/b_consolidated_3850_3e_cg/b_consolidated_3850_3e_cg_chapter_01100011.html
Remember to use the correct file name for the release version you want
Alex
