05-06-2016 08:48 AM - edited 03-08-2019 05:38 AM
I'm getting ready to replace some of the Virtual Gateways (VG224) at one of my sites and have a few concerns:
Solved! Go to Solution.
05-10-2016 06:44 AM
Yahya,
Hope you doing well...
V is standing for VOICE, not virtual. So vg224 will be voice gateway224. The answers for your quastion will be...
1- Yes, it's sufficient.
2- CUCM administration page > device > gateway > find. Then select your gateway, change mac address ( 10 digits ) of the old device with the new one.
3- with using sccp protocol, CUCM don't care about ip address, it's only care about mac address. So the answer will be, NO .
hope that could help
05-25-2016 03:07 AM
stcapp not enabled. Do run the command VG224-1(config)#stcapp. inform me about the results please.
05-07-2016 06:23 AM
First you have to tell us in which protocol did your vg224 works on ??
05-10-2016 06:08 AM
I use SCCP for my protocol.
Thanks for your anticipated assistance.
05-10-2016 06:44 AM
Yahya,
05-23-2016 11:43 AM
Hi, and thanks for your reply.
Upon replacing the VG224 none of the analog phones registered on the CUCM. I ran sh sccp on the new VG224 and received "SCCP application services(dspfarm profiles) are not enabled or haven't associated to SCCP CCM group". I tried to reset the SCCP (no sccp/sccp) and that didn't seem to fix the issue.
I copied the original configuration exactly as is to the new VG224, only thing I changed was the passwords, would that be the reason?
Thanks again for your help.
05-24-2016 01:56 AM
The answer to your question number (2), did you worked with it ?
05-24-2016 04:20 AM
Hi Saif,
Yes, I did change the MAC address in the CUCM to the new VG224.
Thanks for your kind support.
05-24-2016 09:23 AM
Yahya,
Cisco vg224 have 2 fastethernet port on its back, did you connect the same interface as the old one ? If yes, then please upload the running configuration of the device here. It will be easier to troubleshoot.
05-24-2016 11:01 AM
Yes, used same port (Fa0/0) as the old VG224 with same configs and IP addresses. I know that network and vlan routing is not the issue here as I can ping all sides from the new VG224 just fine and the old VG224 works fine when I put it back in place.
See current configuration below, and thanks again for your help.
Building configuration...
Current configuration : 5445 bytes
version 15.1
no service pad
hostname VG224-1
boot-start-marker
boot system slot0:vg224-i6s-mz.151-4.M10.bin
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip source-route
ip cef
ip domain name corp.local
no ip dhcp use vrf connected
no ipv6 cef
stcapp register capability 2/0 modem-passthrough
stcapp register capability 2/1 modem-passthrough
stcapp register capability 2/2 modem-passthrough
stcapp register capability 2/3 modem-passthrough
stcapp register capability 2/4 modem-passthrough
stcapp register capability 2/5 modem-passthrough
stcapp ccm-group 1
stcapp feature access-code
stcapp supplementary-services
port 2/0
fallback-dn 1336
port 2/1
fallback-dn 3633
port 2/2
fallback-dn 0425
port 2/3
fallback-dn 1929
port 2/4
fallback-dn 8692
port 2/5
fallback-dn 5926
port 2/6
fallback-dn 5952
port 2/7
fallback-dn 5953
port 2/8
fallback-dn 5954
port 2/9
fallback-dn 5955
port 2/10
fallback-dn 5959
port 2/22
fallback-dn 5600
stcapp call-control mode feature
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
h323
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice-card 0
archive
log config
hidekeys
username xxxxx privilege 15 secret xxxxx
interface FastEthernet0/0
ip address 192.168.1.20 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp-server community xxxx
control-plane
voice-port 2/0
timeouts ringing infinity
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
no ccm-manager fax protocol cisco
mgcp fax t38 ecm
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 192.168.3.4 identifier 1 priority 1 version 7.0
sccp ccm 192.168.2.7 identifier 2 priority 2 version 7.0
sccp ccm 192.168.2.8 identifier 3 priority 3 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
dial-peer voice 500 pots
service stcapp
fax rate disable
port 2/0
dial-peer voice 501 pots
service stcapp
fax rate disable
port 2/1
dial-peer voice 502 pots
service stcapp
fax rate disable
port 2/2
dial-peer voice 503 pots
service stcapp
fax rate disable
port 2/3
dial-peer voice 504 pots
service stcapp
fax rate disable
port 2/4
dial-peer voice 505 pots
service stcapp
fax rate disable
port 2/5
dial-peer voice 506 pots
service stcapp
fax rate disable
port 2/6
dial-peer voice 507 pots
service stcapp
fax rate disable
port 2/7
dial-peer voice 508 pots
service stcapp
fax rate disable
port 2/8
dial-peer voice 509 pots
service stcapp
fax rate disable
port 2/9
dial-peer voice 510 pots
service stcapp
fax rate disable
port 2/10
dial-peer voice 511 pots
service stcapp
fax rate disable
port 2/11
dial-peer voice 512 pots
service stcapp
fax rate disable
port 2/12
dial-peer voice 513 pots
service stcapp
fax rate disable
port 2/13
dial-peer voice 514 pots
service stcapp
fax rate disable
port 2/14
dial-peer voice 515 pots
service stcapp
fax rate disable
port 2/15
dial-peer voice 516 pots
service stcapp
fax rate disable
port 2/16
dial-peer voice 517 pots
service stcapp
fax rate disable
port 2/17
dial-peer voice 518 pots
service stcapp
fax rate disable
port 2/18
dial-peer voice 519 pots
service stcapp
fax rate disable
port 2/19
dial-peer voice 520 pots
service stcapp
fax rate disable
port 2/20
dial-peer voice 521 pots
service stcapp
fax rate disable
port 2/21
dial-peer voice 522 pots
service stcapp
fax rate disable
port 2/22
dial-peer voice 523 pots
service stcapp
fax rate disable
port 2/23
dial-peer voice 200 voip
destination-pattern 8T
session target ipv4:192.168.1.1
dtmf-relay rtp-nte digit-drop
codec g711ulaw
fax rate disable
line con 0
line aux 0
line vty 0 4
transport input all
end
VG224-1#sh sccp all
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
IPv4 Address: 192.168.1.20
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.2.8, Port Number: 2000
Priority: 3, Version: 7.0, Identifier: 3
Call Manager: 192.168.2.7, Port Number: 2000
Priority: 2, Version: 7.0, Identifier: 2
Call Manager: 192.168.3.4, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
CCM Group Identifier: 1
Description: None
Binded Interface: None
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 2, Priority in this CCM Group: 2
Associated CCM Id: 3, Priority in this CCM Group: 3
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total Video Conferencing Sessions: 0, Connections: 0
Total Video Transcoding Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
No SCCP server info to display
VG224-1#
05-25-2016 03:07 AM
05-26-2016 06:24 AM
Hi Saif,
Enabling stcapp totally fixed the issue and the new VG224 is working now.
Thank you so much for your help.
10-06-2017 11:43 AM
Hey, that fixed my VG204 not associating with CM. Thank you!!
Enables SCCP
VG204(config)#stcapp ccm-group 1
Bam!
05-15-2019 06:24 PM
Thank you Saif. I spent endless hours troubleshooting an analog phone registration failure and all I had to do was conf t -> stcapp. So Simple. THANK YOU.
