05-09-2016 08:09 AM - edited 03-10-2019 11:45 PM
Hello, I want permit user only use sub-tab Security > Mac Fillter on Wireless Controller through ACS 5.8. I think it unavailable for Gui so i config throught comand set. But not success. Please help me
Solved! Go to Solution.
05-10-2016 11:13 AM
The GUI should be role based using TACACS+ authorization, but not with command lists like switches :
Authorization—The process of determining the actions that users are allowed to take on the controller based on their level of access.
For TACACS+, authorization is based on privilege (or role) rather than specific actions. The available roles correspond to the seven menu options on the controller GUI: MONITOR, WLAN, CONTROLLER, WIRELESS, SECURITY, MANAGEMENT, and COMMANDS. An additional role, LOBBY, is available for users who require only lobby ambassador privileges. The roles to which users are assigned are configured on the TACACS+ server. Users can be authorized for one or more roles. The minimum authorization is MONITOR only, and the maximum is ALL, which authorizes the user to execute the functionality associated with all seven menu options. For example, a user who is assigned the role of SECURITY can make changes to any items appearing on the Security menu (or designated as security commands in the case of the CLI). If users are not authorized for a particular role (such as WLAN), they can still access that menu option in read-only mode (or the associated CLI show commands). If the TACACS+ authorization server becomes unreachable or unable to authorize, users are unable to log into the controller.
Taken from :
05-10-2016 11:13 AM
Taken from :
