05-10-2016 10:58 AM
What is VPN Termination and How many Cisco Routers can Handle ?
Thank you
05-13-2016 02:53 AM
by VPN Termination, do you mean Site-to-Site VPN?
Depending on your VPN setup, some routers can handle it, some cannot.
Which router do you have?
Please check out Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
05-13-2016 07:53 AM
How many VPN tunnels a router can handle at a single time?
What is the usual practice in the industry?
05-13-2016 09:53 AM
Due to the variety of routers out there, you cannot really answer that question. It all depends on which router you have, the image and licence for it. Some high end routers can handle more then the small business ones.
Often you might have an ASA controlling the VPN connections as well. So to answer your question, it depends.
05-13-2016 10:01 AM
Minimum
Maximum
05-13-2016 10:10 AM
As I wrote before, some routers cannot handle any at all.
ASA 5505 / Security Plus
Maximum Site to Site VPNs:
10/25
ASA 5506-X / Security Plus
10/50
ASA 5515-X
250
ASA 5555-X
5,000
Please note that the answers here is still, it depends. How fast is your connection to your ISP? How much data is being sent over the VPNs etc.
