Integration CM and Huawei AR2200 router with E1 and fxo
leandro.tomas1
Hi all, I have CUCM 8.6 with h323 gateways for branches. It branch (cisco router) has E1 and FXO lines to make external call (dial-peer voice pots) and dial-peer voice voip to route calls to main office or between branches . So far , so goog.
Now we are installing new Huawei AR2200, to work as redundancy for Cisco router one, in case cisco fails or whatever. Need some help how to define the dual for dial-peer voice, voice-port , controller E1 and how to set them up. Seems to be similar to cisco but it does not.
Jaime Valencia
If you need assistance on the actual Huawei device as to what/how to configure, you should reach out to them directly for this.
java
if this helps, please rate
