Expressway-E Dual NICs
JustForVoice_2
Level 4
Level 4
I want to use Expressway-E Dual NIC deployment. Could you please infrom me if the IP settings for NIC interfaces are OK as per the attached image?
Please check page 51-52 of the following link for how it works
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Cisco-Expressway-Basic-Configuration-Deployment-Guide-X8-5-2.pdf
Manish
Manish Gogna
That looks correct as per pages 23-24 of the following link
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/admin_guide/Cisco-Expressway-Administrator-Guide-X8-2.pdf
LAN 1 and LAN2 interfaces must be on different, non overlapping subnets.
Manish
Thank you for your reply, but I have a question regarding the communication between Expressway-C and E. While C in different network how E will communicate with C and no default GW?
Manish
Essentially this is achieved by adding static routes to the E server to point all internal networks to the "Transit DMZ" (internal DMZ), and then everything else goes to the "Services DMZ".
