UCS B200M3 server 2-adapters unreachable
I have a UCS with 6 servers installed in version 2.2.6e
2 servers are B200M4 and 4 servers are B200M3
one of the B200M3 server installed in slot 5 display error: Adapter 1/5/1 is unreachable. Also for Adapter 1/5/2
It affect all LAN nics to be down and VIF paths is unpinned and give Error
And in Faults page of the server, it shows: Adapter host interface 1/5/1/x link state: down . x is repeated for all nic numbers
Also  Adapter host interface 1/5/2/x link state down for the second adapter
And inform that Adapter 1/5/1 and 1/5/2 is unreachable
I tried to re-acknowledge the server and the chassis with no success
Also de-associate the service profile and reassociate with no help
Also decommission the server then recommission it with no success
Also I have reset all the chassis and FIs with no help
Still adapter not reachable
From FI cli , I found the following output
UCS /chassis/server # show adapter
Adapter:
    Id         PID          Vendor          Serial          Overall Status
             1 UCSB-MLOM-40G-01
                            Cisco Systems I XXXXXXXXX     Operable
             2 UCS-VIC-M82-8P
The above is the 2 adapters. The same adapters is working good for other 3 B200M3 servers
So please help what may be the cause. plz note that it happen suddenly with no action from our side
I'm thinking to remove the server and re-insert the adapter cards and insert it again !!
Haitham
AFROJ AHMAD
Hi Haitham,
Check the Adapter reachablilty like below::
ucs-B# connect adapter 1/5/1
adapter 3/1/1 # connect
127.8.3.17: No route to host        >>>> mean some issue with Adpater (Non-working)
adapter 3/1/1 # exit
ucs-B# connect adapter 1/5/2
adapter 3/1/2 # connect
adapter 3/1/2 (top):1#  >>>> working one
for the Non-working , try to reseat the Adapter once ,if it fix the issue then great otherwise Replace the adpater.
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
