The only message with that string that I could find in the guide is the following:
Error Message DHCP_SNOOPING-4-QUEUE_FULL: Fail to enqueue DHCP packet into processing queue: [chars], the queue is most likely full and the packet will be dropped.
Explanation The CPU is receiving DHCP at a higher rate than the DHCP snooping can process. These DHCP packets are dropped to prevent a denial of service attack. [chars] is the warning.
Recommended Action No action is required.
As the number "4" in the message ID indicates, it is a severity level 4 or warning message.
Reference: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/15-0_2_se/system/message/smg3750.pdf
