Prme template question
bberry
I am a very new user to prime and am just starting to get into creating templates so have two questions.
1) Can anyone recommend a reference source to help me understand the programming side of the templates. I have been going through the pre-canned templates and it looks straight forward to a point but need a bit more explanation on the syntax stuff.
2) This may be because I do not have a firm handle on question #1. How do I get the template to save the config after making a change? I created a basic template to do a no username and it is successful. When I look at the running config it is gone. When I look at the startup config though it is sill there. I have tried several different combinations that I thought should work but keep getting a failure. In looking through the pre-canned templates none of these seem to have a method to save the config either.
Brent
Dhammike
Hi bberry,
For your Q2, you can simply tick "Copy Running Config to Startup" under the job options on template deployment wizard.
Dhammike.
I must be missing something as I do not have that option. I am using deploy - Configuration Tasks - my templates - selecting my test template - then deploy on menu bar. I then have device selection - value assignment and schedule boxes for options.
Brent
