Dhcp snooping is for switches where client devices connect. Users are not directly connected to router and hence, ip dhcp snooping command is not required on routers like the 2800
Ip verify source is supported on 3560 switches. If it is not available on your switch, then you have a very old IOS version.
John
**Please rate posts you find helpful**
