05-19-2016 01:44 PM - edited 03-10-2019 12:39 AM
Guys, I need to take that exam within the next 4 weeks or before. Could you advise what Cisco press book should I get to study from ?.
Edouard.
01-23-2017 12:06 AM
Hi Edouard,
Did u gave exam?
01-23-2017 08:37 AM
This link has everything you need to pass the exam. Make sure you get the newest version of the training. You can also download the transcripts, instead of just watching the videos over and over. https://salesconnect.cisco.com/#/briefcase-details/P03171180
06-26-2017 02:00 AM
Can't find the transcripts. How to get them on Cisco SalesConnect ? ( Any change for a direct link to one of the sessions ? )
06-26-2017 08:34 AM
Not sure if the link changed, but the transcripts should be in the same page that you go to when you download the videos. You might just have to search a bit for them.
06-26-2017 10:47 AM
I never found the transcripts either.
I studied from the videos and some of the materials from the fire jumper to be able to pass the exam
09-27-2017 08:32 AM
Ciao,
I passed the exam yesterday. Thanks for the information.
10-20-2017 03:46 PM
11-15-2017 07:08 AM
Ciao,
yes https://salesconnect.cisco.com/#/briefcase-details/P03171180 is enough to pass the exam.
11-15-2017 07:05 AM
A discrepancy between narrator and slides?
ASAS- Security Architectue Solutions - Mod 2 - Video
In the video module 2 at 3:07, the narrator states that there are “over 150 million end points analyzed around the world”. The accompanying slide shows 1.6 million global sensors. Are end points and global sensors different? If they are the same, which number is correct?
11-15-2017 07:10 AM
Ciao,
probably the 150 million end points are the User's PC and the sensor are devices like ASA, FTD, etc..
