IT operation Assistant
dear all
i m using the WLC 2504  with  AP indoor 3600  and out door  1550
i planning to add one  more 1530 serie  please  advice  but i m not able  to manage
Garba Souley
What is the software version running on your 2504 ? 1530 series require min 7.6.x code. Refer table 2 of this document
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
I would suggest you to upgrade 8.0MR3 code. Refer below for release note of that code
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr3.html
Rasika
*** Pls rate all useful responses ***
George Stefanick
If you are on newer code you should not have any issues.
