CUCM Menu in spanish
luis_Borja
I have an CUCM 10.5 version, my costumer wants that menu in webpage administration appears in spanish, how can I configure it????
thanks for your support.
12 Replies 12
Deepak Rawat
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-71/113395-cucm-locale-nl-00.html
Deepak
Hi deepak,
I do it, but the menu in spanish does not appears, it is in english.
http://docwiki.cisco.com/wiki/CUCM_FAQ#How_do_I_change_the_language_from_the_admin_interface_.2F_UCMuser.3F.3F.3F
Deepak
HI deepak, venperum
I have configure in all my browsers spanish language.
regards
Notice that the locale you installed, has to match the language from the browser, if you install spanish Colombia and use spanish Spain in the browser, it will NOT work.
java
if this helps, please rate
Hi venperum, Jaime
yes I install the locale on all nodes of cluster.
and yes I install spanish colombia, I was configuring spanish Mexico in my browser, I just configure now with spanish colombia but it is not working.
regards.
What is your exact CUCM ?
Do you see it properly installed if you do a show version active?
I just did this in my lab last week and it worked just fine.
java
Hi Jaime
I attach a show version active from the CUCM 10.5.2.10000-5 version.
The only difference is the version, but I have the same locale working in my lab.
Try with Firefox.
java
HI Jaime,
I tried with firefox and chrome, is the same problem, another suggestion???
regards
also, did you install the locale on all the servers followed by a cluster reboot.
you need to change your browser language to the locale you installed.
