05-22-2016 04:44 AM - edited 03-01-2019 12:44 PM
I'm connecting second ucs chassis to a fabric interconnect . How to copy a service profile from the 1st to 2nd chassis
and is ucs director need license
and is there best practice for this new chassis
Solved! Go to Solution.
05-22-2016 07:15 AM
Hythim,
Are both these chassis in the same domain? (Under the same cluster IP address?) If so, you can just create new Service Profiles from the templates. If they are in two different domains, yes, copying XML or just re-creating the template in the new domain would probably be easiest.
If you had UCS Central, you could join both domains to Central and just use Global Service Profiles and avoid the problem all together.
HTH,
Wes
05-22-2016 05:08 AM
Hythim,
There are quite a few options when using different service profiles with new blades. You may opt to:
-Clone existing service profiles from existing service profiles.
-Created new service profiles from existing initial/updating templates.
-Create new service profile all together.
It just depends on what your needs are as far as deployment.
Here is an FAQ on UCS Director Licensing:
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-director/200218-UCS-Director-licensing-FAQ.html
As far as best practice, make sure you are using Port-Channel link policy for your FI to IOM connections.
HTH,
Wes
05-22-2016 06:49 AM
Hi Wesley,
Thanks for your reply
I mean copying templates between 2 different chassis. From the old to the new.
Is copying xml is valid or there is a better way?
05-22-2016 07:15 AM
Hythim,
HTH,
Wes
05-22-2016 07:25 AM
Great
kindly what is the use of ucs director and something called cisco one in this case
thanks again
05-22-2016 08:14 AM
Here is information on Cisco ONE and UCS Director use cases:
http://www.cisco.com/c/en/us/products/collateral/software/one-data-center/datasheet-c78-733594.html
http://www.cisco.com/c/en/us/products/software/one-data-center/data-center-computec-part.html
HTH,
Wes
