ā05-23-2016 02:47 AM
We use the ironport ESA C170 for filtering incoming mail with a accept query validation, thats works fine but some users use the plus - addressing feature to generate dynamic Mail Addresses for filtering in the Inbox. The syntax of this is proxyaddress+somesuffix@domain.tld It is possible to change the query string to this pattern. The suffix is unknown in the AD so I cannot add each suffix to the AD as proxyaddress.
This is the actual query string:
For example the proxy address is user@domain.tld and for a project the user use user+project1@domain.tld and for that the query string don't match. The Filter reject the Mail with:
To: <user+project1@domain.tld> Rejected by LDAPACCEPT
I don't want to deactivate this Feature, so I'am searching a syntax that match this pattern.
ā01-24-2020 12:53 AM
Did you ever find a solution for this?
ā01-24-2020 04:04 AM
Hi all, please refer the manual page below:
