05-24-2016 03:55 AM - edited 03-08-2019 05:54 AM
Hi all,
I need some hints. I have to connect one VSS with 2 stacks in this way:
- VSS connected to stack 1 with fiber 1
- VSS connected to stack 2 with fiber 2
- stack 1 connected to stack 2 with fiber 3
Problem is that I need a sort of fault tolerance that should work in this way:
- fiber 1 is the only active link
- fiber 2 is in a sort of standby mode
- so stack 2 can reach VSS by fiber 3
I think that I could let the VSS manage this link by spanning-tree but I really don't know how I should set the fiber ports.
Any idea?
05-24-2016 04:14 AM
Make stack#1 as STP Root bridge. the link between Stack#2 and VSS will be automatically blocked.
if you dont want STP to manage this, you can think of flex links.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/flexlink.html#wp1039328
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vss.html#wp1063892
why making it complex.. just go with STP :)
05-24-2016 06:18 AM
Hi Furose,
thank you for the answer! I think I'll manage by STP as you told me. Should I configure only the fiber 1 and fiber 2 ports or do I need to configure the fiber 3 ports too?
(I've never used STP before, except for standard configuration :-( )
05-24-2016 06:30 AM
you dont need to configure anything explicitly except "spanning root primary" in stack#1, if you wish to make it as Root bridge.
you can configure all the 3 links as normal trunk link or access link (depending on your design).
i would generally recommend using VSS as the STP root if it is the core of the network, but, to achieve your goal, this is the option.
05-24-2016 06:52 AM
indeed the VSS is the core of the network and it's connected to other stacks too.
regarding the 3 links, they all will be configured as trunk.
I'll take a look, thank you
05-24-2016 06:56 AM
if there are other stacks, then i would recommend leaving it as STP root and think about flex link option :)
05-24-2016 08:03 AM
Hello
To clarify can you post a topology
res
Paul
05-31-2016 07:27 AM
that's what I want to do
http://i.imgur.com/9PmOfJm.jpg
I wanna use one fiber link vs VSS at time. Just for claryfing, stack 1 and stack 2 use fiber 2 only when fiber 1 goes down.
