Migrate NAC Server to ISE
alibarzoodeh
Hello all.
I have SNS-3495-K9 with license for 1500 endpoints. Can I migrate NAC software to Identity Service Engine?
nspasov
Hi there, you will need to contact your local Cisco re-seller and inquire about this. Depending on the region that you are located you might qualify for migration licenses/SKUs.
I hope this helps!
Thank you for rating helpful posts!
