05-26-2016 01:32 PM - edited 03-17-2019 07:03 AM
I have a cisco callmanager 7.1 that notifies the person who is on-call if there has been a voicemail left on the system. Recently we have been getting some calls from unknown/null numbers that all the message is is several beeps. I found how to block these using a voice translation-rule, however i can't figure out how to integrate it with our current setup. I didn't originally set this up and I am not fully uptodate on my cisco IOS commands so i don't fully understand what was setup.
here is what I want to "add" : http://www.gossamer-threads.com/lists/cisco/voip/86237
Here is what I have
voice translation-rule 1
rule 1 /^.*/ /8102277544/
voice translation-profile SRST-OUTGOING
translate calling 1
dial-peer voice 1 voip
description **INCOMING PEER**
session protocol sipv2
session target sip-server
incoming called-number 81049406..
dtmf-relay rtp-nte
codec g711ulaw
05-27-2016 01:28 PM
You can do exactly what you found from that thread on your own router. What are your questions or doubts?
Tim
05-31-2016 07:03 AM
I want to integrate these new commands with the current ones that are in place and not disrupt anything. Will Tagir's commands do this?
05-31-2016 07:27 AM
The rules are processed top-down so you would need to make the rule as follows:
rule 2 reject /^$/
05-31-2016 08:14 AM
outgoing and incoming
05-31-2016 08:41 AM
I forgot to mention that I have a great number of other dial-peers, but for the sake of security, I didn't post them all in the original.
05-29-2016 11:50 AM
conf t
voice translation-rule 10
rule 1 reject /^$/
voice translation-profile block
translate calling 10
call-block translation-profile incoming block
exit
wr
