05-27-2016 02:59 AM - edited 03-08-2019 05:58 AM
HI,
We have two isp links and both are terminated in single router with vrrp & BGP, when both routers on live ISP links fluctuation is happened , but its working fine with single router, we want HA for the Router also. Please find the master router configuration and help on this..
neinho23-primary#sh run
Building configuration...
Current configuration : 4350 bytes
! Last configuration change at 23:50:36 UTC Thu May 26 2016
! NVRAM config last updated at 23:53:44 UTC Thu May 26 2016
version 15.1
hostname neinho23-primary
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO2911/K9 sn FGL164811FW
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.206.10.23 255.255.255.0
duplex auto
speed auto
vrrp 1 ip 10.206.10.9
vrrp 1 preempt delay minimum 300
vrrp 1 priority 200
interface GigabitEthernet0/1
description tata_mpls
ip address 172.30.170.75 255.255.255.248
duplex auto
speed auto
vrrp 1 ip 172.30.170.74
vrrp 1 priority 200
interface GigabitEthernet0/2
description reliance_mpls
ip address 10.227.76.251 255.255.255.248
duplex auto
speed auto
vrrp 1 ip 10.227.76.250
vrrp 1 priority 200
interface FastEthernet0/0/0
ip address 10.206.50.2 255.255.255.0
duplex auto
speed auto
vrrp 1 ip 10.206.50.1
vrrp 1 priority 200
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
description bsnl_p2p
ip address 3.1.3.1 255.255.255.252
encapsulation ppp
router rip
version 2
network 3.0.0.0
network 10.0.0.0
router bgp 65211
bgp log-neighbor-changes
network 10.206.0.0 mask 255.255.0.0
network 10.206.10.0 mask 255.255.255.0
network 10.206.11.0 mask 255.255.255.0
network 10.206.12.0 mask 255.255.255.0
network 10.206.13.0 mask 255.255.255.0
network 10.206.14.0 mask 255.255.255.0
network 10.206.15.0 mask 255.255.255.0
network 10.206.16.0 mask 255.255.255.0
network 10.206.17.0 mask 255.255.255.0
network 10.206.18.0 mask 255.255.255.0
network 10.206.19.0 mask 255.255.255.0
network 10.206.20.0 mask 255.255.255.0
network 10.206.21.0 mask 255.255.255.0
network 10.206.22.0 mask 255.255.255.0
network 10.206.23.0 mask 255.255.255.0
network 10.206.24.0 mask 255.255.255.0
network 10.206.25.0 mask 255.255.255.0
network 10.206.27.0 mask 255.255.255.0
network 10.206.29.0 mask 255.255.255.0
network 10.206.30.0 mask 255.255.255.0
network 10.206.31.0 mask 255.255.255.0
network 10.206.32.0 mask 255.255.255.0
network 10.206.33.0 mask 255.255.255.0
network 10.206.35.0 mask 255.255.255.0
network 10.206.50.0 mask 255.255.255.0
network 10.206.60.0 mask 255.255.255.0
network 10.218.0.0 mask 255.255.255.0
network 10.218.1.0 mask 255.255.255.0
network 10.227.76.0 mask 255.255.255.192
network 172.30.170.0 mask 255.255.255.192
network 182.156.86.0 mask 255.255.255.192
network 203.124.152.0 mask 255.255.255.192
neighbor 10.227.76.249 remote-as 18101
neighbor 10.227.76.249 description ### reliance BGP Peering###
neighbor 10.227.76.249 ebgp-multihop 4
neighbor 10.227.76.249 default-originate
neighbor 10.227.76.249 soft-reconfiguration inbound
neighbor 172.30.170.73 remote-as 65000
neighbor 172.30.170.73 description ###TATA BGP Peering ####
neighbor 172.30.170.73 ebgp-multihop 4
neighbor 172.30.170.73 default-originate
neighbor 172.30.170.73 soft-reconfiguration inbound
no ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.206.10.1 name Internet
ip route 10.206.10.0 255.255.255.0 10.206.10.1 name NEINLAN
ip route 10.206.14.0 255.255.255.0 3.1.3.2 name NEINBLRAIR
ip route 10.218.0.0 255.255.255.0 10.206.10.1 name NEHHKG
ip route 10.218.1.0 255.255.255.0 10.206.10.1 name NEHHKG
access-list 100 permit ip 10.206.0.0 0.0.255.255 any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password cisco
login
transport input all
scheduler allocate 20000 1000
end
neinho23-primary#
Muthukuar
05-27-2016 12:17 PM
Do you want both links to be active and in use at the same time, or active/standby?
05-29-2016 01:02 AM
HI,
I want active & active ...
Muthukumar
05-29-2016 01:15 AM
I need ISP link is active & active and router is Active & standby..
Muthukumar
05-30-2016 12:20 AM
HI,
Please help on this..
Muthukumar
05-30-2016 01:20 AM
Could you not just use GLBP as its active/active by default or else split the subnets have multiple groups to make active/active in HSRP or VRRP , its a active/standby protocol so its not really suited for active/active
05-30-2016 02:00 AM
Hi ,
Can i get the GLBP configuration for this ?and can you confirm that whether GLBP supported for cisco 2911 router..
Muthukumar
05-30-2016 02:15 AM
yes its supported , just change the vrrp to glbp
https://supportforums.cisco.com/document/23466/how-configure-glbp
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp_fhrp/configuration/xe-3s/fhp-xe-3s-book/fhp-glbp.html#GUID-A2D19870-5191-4181-B02F-D4810F9789E3
05-30-2016 09:27 PM
I am understanding that GLBP for Router HA right..Can i get link load balancing for ISP Link and pls suggest, whether both isp link terminated to single router or separate router..
Muthukumar
05-31-2016 12:31 AM
If your using BGP you need to look at single/multi BGP homing load sharing you can manipulate the metrics to chose what to be learnt etc from each ISP as primary/secondary paths
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
05-27-2016 07:58 PM
Hello Muthukumar,
So you have 2 routers connected to your provider. Also there are 4 interfaces on this device configured for VRRP group 1, this might cause conflict as the VIP address will have 4 differents IP addresses, such a thing is not possible.
How these interfaces are connected to the other router? Maybe you can either define more than one VRRP group.
-Max
05-29-2016 01:04 AM
Hi Max,
Earlier i have tried with 4 vrrp group means each interface is having each group even also ISP Link is flapping when both routers are in live..
Muthukumar
