User Hold Audio Source and Network Hold Audio Source not being updated for UCCX version 11
rahzby.talukder
Good Day. We have changed the User Hold Audio Source and Network Hold Audio Source in the UCCX but we can still hear the previous setup. We tried restarting the server several times but same result is this is a bug? since this is the only current version of UCCX wherein we encounter that issue.
Thank you
Deepak Rawat
Can you make sure that the MOH you want to play is uploaded on all the CM/MOH servers by going to below location of all the CM/MOH servers individually
Cisco Unified CM Administration >> Media Resources >> MOH Audio File Management
Also, please reset the CTI ports from CUCM. You will need to go to Cisco Unified CM Administration >> Device >> Phone and then do a search like below:
Find Phone where Device Name begins with <Device Name Prefix> that you have configured for the Call Control Group in UCCX. This way it will list all the CTI Ports for that particular Call Control Group, select them all and do a reset.
Deepak
