ā05-28-2016 12:18 AM - edited ā03-08-2019 05:58 AM
which command can see the number of duplicate ack
Solved! Go to Solution.
ā05-28-2016 04:05 AM
If you are using Wireshark, Filter for "tcp.analysis.duplicate_ack".
ā05-29-2016 01:31 AM
how many seconds should we use count the number of duplicate ack?
what is the period to use when count number of duplicate ack?
ā05-29-2016 02:41 PM
Really I don't care about "time period" for the dup. Acks., I care about its origins, type of duplicated packets and it's impact on network performance. But if you want me to say something about "time period" then I will choose to count duplication for approximately 20 sec.
