05-28-2016 12:23 PM - edited 03-08-2019 05:58 AM
I am setting two ESX hosts and have them connected to my TE ports on my C6880 switch. All VLAN information has been configured, but I cannot ping the host, the host cannot ping the gateway.
Is there something different you have to configure for Ten Gig cards to route?
05-28-2016 02:28 PM
Those ports are the same as any other ports.
Can you post the config from the 6880 and also give us the IP info?
05-28-2016 02:40 PM
Thanks for the reply.
Here are how I have the ports configured:
interface TenGigabitEthernet1/1/1
switchport
switchport mode access
switchport trunk allowed vlan 1
switchport access vlan 10
spanning-tree portfast edge
interface TenGigabitEthernet1/1/2
switchport
interface TenGigabitEthernet1/1/3
switchport
interface TenGigabitEthernet1/1/4
switchport
interface TenGigabitEthernet1/1/5
switchport
interface TenGigabitEthernet1/1/6
switchport
interface TenGigabitEthernet1/1/7
switchport
interface TenGigabitEthernet1/1/8
switchport
interface TenGigabitEthernet1/1/9
switchport
interface TenGigabitEthernet1/1/10
switchport
05-28-2016 02:46 PM
You need the ports to be configured as access port? If so than you don't need this command
example:
switchport
Also can you post the SVI for vlan 10? Is it configured ?
if yes, is it up and running
sh run in vlan 10
Also, what is the output of "sh vlan"
05-28-2016 03:18 PM
Reza,
here is more of my VLAN information:
VLAN Name Status Ports
10 VLAN0010 active Te1/1/1, Te1/1/2, Te1/1/3
Te1/1/4, Te1/1/5, Te1/1/6
Te1/1/7, Te1/1/8, Te1/1/9
Te1/1/10, Gi101/1/0/17
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
--More--
40 enet 100040 1500 - - - - - 0 0
50 enet 100050 1500 - - - - - 0 0
60 enet 100060 1500 - - - - - 0 0
61 enet 100061 1500 - - - - - 0 0
62 enet 100062 1500 - - - - - 0 0
70 enet 100070 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
show vlan summary
Number of existing VLANs : 14
Number of existing VTP VLANs : 14
Number of existing extended VLANS : 0
sh ip interface brief | i Vlan
Vlan1 10.0.0.100 YES NVRAM up up
Vlan10 10.2.0.10 YES NVRAM up up
Vlan30 10.3.2.10 YES NVRAM up up
Vlan40 10.3.4.20 YES NVRAM up up
Vlan60 10.10.0.10 YES NVRAM up up
Vlan61 10.10.2.1 YES NVRAM up up
Vlan62 10.10.3.1 YES NVRAM up up
Vlan1006 192.168.1.1 YES unset up up
sh run in vlan 10
Current configuration : 86 bytes
interface Vlan10
description Servers_VLAN
ip address 10.2.0.10 255.255.254.0
end
05-28-2016 03:26 PM
Vlan 10 seems to be configured correctly and the SVI for it is up. Is the ESXi hosts configured with correct IP subnet, address and mask?
Do you see the MAC address of the NIC for the ESXi hosts on the switch?
"sh mac address-table" should show you what ports they are connected to
05-28-2016 03:29 PM
Yes the ESX hosts shows up in the mac address table. But I can't ping it from the switch.
Or from the ESX host I can't ping the gateway on the switch.
I am stumped!
05-28-2016 03:32 PM
But the IPs and masks are configured correctly?
Do you have another device (not ESXi) to connect to the switch for testing?
05-28-2016 03:36 PM
Yes the IP address, subnet mask and gateway are all correct. I have two brand new ESX hosts, I have tried them both, no luck.
