05-29-2016 12:33 AM - edited 03-05-2019 04:06 AM
What is special in ISR router ? what are the difference between ASR and ISR router ? is there any security or firewall feature integrated in ISR router ?
05-29-2016 09:08 PM
Basically the ASR is a bigger router with a lot more throughput. With the exception of the ASR9000, they run IOS-XE.
ISR comes with firewall you you buy it with an "advanced security" licence or better.
05-30-2016 12:42 AM
Hi Philip
Thanks for your answer, I need little more in detail on ASR router in comparison with ISR router.
Where do we use ASR ? What do you mean by higher throughput?
Could you please write it here ?
05-30-2016 01:51 PM
Here is a comparison of the ASR 1k series. Note the throughputs.
Here is a comparison of the 4000 series routers. Note the throughputs.
Both of these series run IOS-XE - so both run similar software.
05-30-2016 01:52 PM
Here is a comparison of the older ISRG2 routers and the newer 4000 series.
05-30-2016 10:20 PM
Session Initiation Protocol (SIP) sessions - this means concurrent CUBE calls? or call legs? each call 2 call legs?
05-31-2016 05:05 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What's special about an ISR, they support software features and/or hardware, above and beyond just basic routing. For example, they might support voice or they might support WAFS/WAAS, etc.
As also noted by Philip, the ASRs ofter much more performance than ISRs (of course, they're much more costly too).
Again, as also noted by Philip, ISR, depending on feature set, do offer some security and/or FW capabilities. Support for those features, though, isn't generally as good as dedicated appliances.
