vrrp stuck in Init state
Raja_D
I notice an issue in my new setup with vrrp status. When checked from the router 1 and router 2 perspective where the router 1 which is configured with lower priority takes the Master role while the router 2 which is configured with higher priority takes the Init role without getting into the Master state. Below is the configuration. Please advise for any changes which can set right the vrrp status.
ACL LAB config
ip access-list extended LAB
10 permit ip any 10.0.0.0 0.255.255.255
20 permit ip any 224.0.0.0 15.255.255.255
30 deny ip any any
Router 1 interface configuration:
interface FastEthernet0/0
ip address 20.45.21.150 255.255.255.192
ip access-group LAB in
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip flow ingress
ip flow egress
ip pim dr-priority 200
ip pim sparse-mode
load-interval 30
speed 100
full-duplex
vrrp 1 ip 20.45.21.149
vrrp 1 timers learn
vrrp 1 priority 150
vrrp 1 track 1 decrement 20
fair-queue
no cdp enable
no mop enabled
end
Router 1 vrrp status
show vrrp
FastEthernet0/0 - Group 1
State is Master
Virtual IP address is 20.45.21.149
Virtual MAC address is 0000.5e00.0101
Advertisement interval is 1.000 sec
Preemption enabled
Priority is 150
Track object 1 state Up decrement 20
Master Router is 20.45.21.150 (local), priority is 150
Master Advertisement interval is 1.000 sec
Master Down interval is 3.414 sec
track 1 rtr 92 reachability
show track 1
Track 1
Response Time Reporter 92 reachability
Reachability is Up
1 change, last change 03:44:18
Latest operation return code: OK
Latest RTT (millisecs) 4
Tracked by:
VRRP FastEthernet0/0 1
ip sla 92
icmp-echo 25.24.160.101 source-ip 25.24.160.102
timeout 2000
threshold 2000
frequency 10
ip sla schedule 92 life forever start-time now
Router 2 configuration
interface FastEthernet1
ip address 20.45.21.151 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip pim dr-priority 240
ip pim sparse-mode
no ip mroute-cache
duplex auto
speed 100
vrrp 1 priority 160
vrrp 1 track 2 decrement 20
fair-queue
no cdp enable
end
Router 2 vrrp status
show vrrp
FastEthernet1 - Group 1
State is Init
Preemption is enabled
min delay is 0.000 sec
Priority is 160
Track object 2 state Up decrement 20
Master Router is 20.45.21.150, priority is 150
Master Down interval is 3.375 sec
track 2 rtr 19 reachability
show track 2
Track 2
Response Time Reporter 19 reachability
Reachability is Up
5 changes, last change 04:12:27
Tracked by:
VRRP FastEthernet1 1
rtr 19
type echo protocol ipIcmpEcho 96.52.239.116 source-ipaddr 96.52.239.115
timeout 2000
threshold 2000
frequency 10
rtr schedule 19 life forever start-time now
6 Replies 6
Mark Malone
If you remove that acl does it work ,just wondering as vrrp is 224.0.0.18
are these routers directly connected between those interfaces or is there a layer 2 switch  , is this virtual or physical kit
my vrrp backup router also stuck in init state.
I have a switch in between the two routers any idea?
how are the switchports configured ? Also post the (VVRP) configs of both sides...
Deepak Kumar
I tested the mentioned configuration in my lab and it is working fine without any issue. I hope there is some issue with your switch port configuration. Did you configure any ACL/VACL on the switch?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
Debug vrrp all
Kind Regards
Paul
I had this problem with the Nexus 9k. In my case a no shutdown on the vrrp was necessary.
int vlan 9
vrrp 9
no shut
