how can we determine how much traffic passes through the interface vlan in the Nexus switches,the command (show interface vlan ) doesn't give the needed same as the catalyst,also, (show interface vlan counter) the values we can't read!
The content you are looking for has been archived. View related content below.
Hello, since a few weeks, we are notice a lot of timeouts in our network. We figured out that there are unplanned reboots in our stack. This is what the stack is logging: We are using the stack in a ring-topology in hybrid-mode with the firmware 2.5....
Seeking help how to distribute traffic/load on port channel interface for 2 Catalyst switch.
Hello,I have subnet like this :My pc under vlan 100 (192.168.100.0/24)My NAS under vlan 150 (192.168.150.0/24)Actually when the nas and pc located under same subnet, I can discovery the nas from my laptop using vendor utility, but can't discover when...
Hello, everyone. Our compnay is going to upgrade C9200 software. Can we directly upgrade C9200-48P from 17.03.03 to 17.09.04? 您好,最近相对公司的 C9200 交换机进行软件升级,目前交换机的软件版本是 17.03.03,可以直接升级到最新版本 17.09.04 吗?有没有需要注意的地方?
Hello, I was trying to construct a simple network and got it up the specifications, however when the last step was to configure ipv4 static routes I couldn't quite get it to connect and ping end to end. I tried multiple things but nothing seemed to w...
Hello there.I am trying to upgrade my Switches in installmode to a higher version but it fails, because of invalid image. Switches to upgrade:1x WS-C3850-48P // 2x WS-C3650-48PD IOS in use:16.12.10 CAT3K_CAA-UNIVERSALK9IOS to upgrade to:16.12.10a CAT...
Hello,i'm trying to upgrade my two switch stack from 17.09.04a to 17.09.5. While typing "install add file bootflash:cat9k_iosxe.17.09.05.SPA.bin" i get the following: install_add: START Mon Mar 11 13:22:49 UTC 2024install_add: Adding IMG--- Starting ...
I have a less then a dozen Cisco 3850 switches that I am working on. I need to configure 802.1x authentication. The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x. The Cisco ACS I found out ...
I have 2 IE-4010-4S24P on my bench that when I run a diagnostic start test all I get a failure on TestPortAsicLoopback, after a reload the failure still exists. Does anyone know what could cause this, or is this likely a hardware issue?2) TestPortAsi...
In a NX-OS VPC environment with SVI on the Distribution Switches it's not possible to get a DHCP Client DISCOVER (L2 Broadcast / L3 Broadcast) through the SVI nodes. According to Differences between DHCP relay on the Nexus7000/NXOS and IP Helper on ...
Hello, hoping someone here can help me out.This is post emergency-install to ios version 16.12.10.a the switch fails to fully boot, I have also tried emergency install to 3.7.5E with the same result.Below is the switch bootup output , the contents o...
Hallo zusammen,Ich denke, normalerweise ist eine BFD-Sitzung 1 zu 1, wie unten, oder?Schnittstelle Vlan100IP-Adresse 10.1.1.1 255.255.255.252bfd-Intervall 100 min_rx 100 Multiplikator 5Wenn ich jedoch eine sekundäre IP-Adresse verwenden möchte, ist e...
Hi everyone!I´m a student from CCNA, the problem in my Net is When i ping PC1 from PC7 (or upside down) i get "Desination host unreachable". I want get all devices are connected. One more doubt, how i know MLS and R1 are connected? i don´t understand...
I can't find anything about whether 03.11.07.E supports Reflexive ACL on 4507 with Sup8-E. I did find this but does not clearly specify: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-311xe-4500e.html I cannot drop ...
Subject | Author | Posted |
03-19-2024 02:59 AM | ||
03-19-2024 02:39 AM | ||
03-18-2024 10:42 AM | ||
03-14-2024 06:05 AM | ||
03-13-2024 07:50 PM |
User | Count |
14 | |
14 | |
8 | |
6 | |
5 |
