Auto-tunnel P2MP would not go up - says no Destination configured
Mazzy Star
Hi! I'm having a problem with my mVPN Configuration. Also the Multicast doesn't seem to work intervlan. Hoping someone can help me with this one. Thanks!
RP/0/RSP0/CPU0:ASR9010-1#show mpls traffic-eng tunnels auto-tunnel p2mp
Mon May 30 15:17:21.104 PHT
Name: tunnel-mte2000 (auto-tunnel for MVPN (pim))
   Signalled-Name: auto_ASR9010-1_mt2000
   Status:
     Admin: up  Oper: down
      Reason: No destination is configured
     Config Parameters:
      Bandwidth: 0 kbps (CT0) Priority: 7 7 Affinity: 0x0/0xffff
      Interface Bandwidth: 0 kbps
      Metric Type: TE (default)
      Fast Reroute: Not Enabled, Protection Desired: None
      Record Route: Not Enabled
      Reoptimization after affinity failure: Enabled
      Destination summary: (0 up, 0 down, 0 disabled) Affinity: 0x0/0xffff
      Auto-bw: disabled
    Current LSP:
      None
    Reoptimized LSP (Install Timer Remaining 0 Seconds):
      None
    Cleaned LSP (Cleanup Timer Remaining 0 Seconds):
      None
Displayed 1 (of 16) heads, 0 (of 50) midpoints, 0 (of 14) tails
Displayed 0 up, 1 down, 0 recovering, 0 recovered heads
Below is the configuration:
ipv4 access-list SSM
 10 permit ipv4 232.0.0.0/8 any
 20 permit ipv4 239.0.0.0/8 any
 30 permit ipv4 235.0.0.0/8 any
vrf MulticastIPTV
 vpn id 65001:1111
 address-family ipv4 unicast
  import route-target
   65001:1111
  export route-target
   65001:1111
router bgp 65001
 ! other configs are omitted
address-family ipv4 mvpn
neighbor-group ibgp-session-RR
neighbor-group ibgp-session-RR-client
remote-as 65001
route-reflector-client
next-hop-self
 vrf MulticastIPTV
  rd auto
   redistribute connected
   redistribute static
interface Bundle-Ether3.802
description ***IPTV_MAY2016TEST SOURCE***
vrf MulticastIPTV
ipv4 address 10.20.1.2 255.255.255.0
load-interval 30
encapsulation dot1q 802
interface Bundle-Ether3.803
description ***IPTV_MAY2016TEST DESTINATION ***
vrf MulticastIPTV
ipv4 address 192.168.2.1 255.255.255.0
load-interval 30
encapsulation dot1q 803
interface Loopback300
 vrf MulticastIPTV
 ipv4 address 100.100.102.1 255.255.255.255
route-policy rpf-for-one
set core-tree p2mp-te-partitioned
end-policy
mpls traffic-eng
! interfaces for MPLS are configured but omitted on this page
 auto-tunnel p2mp
  tunnel-id min 2000 max 2999
ipv4 unnumbered mpls traffic-eng Loopback0
multicast-routing
 address-family ipv4
  mdt source Loopback0
  interface all enable
 vrf MulticastIPTV
  address-family ipv4
   mdt source Loopback300
   ssm range SSM
   rate-per-route
   accounting per-prefix
   bgp auto-discovery p2mp-te
   mdt partitioned p2mp-te
   mdt data p2mp-te 100
router pim
 address-family ipv4
  interface Loopback0
   enable
 vrf MulticastIPTV
  address-family ipv4
   rpf topology route-policy rpf-for-one
   mdt c-multicast-routing bgp
    enable
    enable
    enable
Config to other MPLS Routers is similar to the above mentioned configuration
Vinit Jain
Was this working before or is this the first time you have configured it. Also, could you please let me know what is the software version you are running?
I will look into this issue.
Vinit
--Vinit
Hi Vinit,
We're using 5.2.2.
It's now working when I've changed the SSM access-list from 235.x.x.x/8 to 235.1.x.x/24. But the tunnel goes up only with this 1 particular IP 235.1.0.6, when other 235.1.0.X IP is requesting a join, no tunnel is being formed.
What config could possibly correct this?
Since the Source has 1 unicast with multiple multicast IP.
RP/0/RSP0/CPU0:ASR9010-1#sh mpls traffic-eng tunnels p2mp tabular
Wed Jun 29 14:50:00.483 PHT
           Tunnel   LSP     Destination          Source           FRR  LSP  Path
             Name    ID         Address         Address  State  State Role  Prot
  ^tunnel-mte2000     0         Unknown         0.0.0.0   down  Inact Head
  ^tunnel-mte2044 10002  172.31.128.103    172.31.128.1     up  Inact Head
RP/0/RSP0/CPU0:MESJN-ASR9010-1#sh pim vrf IPTV_Bronze topology
Wed Jun 29 14:51:00.749 PHT
IP PIM Multicast Topology Table
Entry state: (*/S,G)[RPT/SPT] Protocol Uptime Info
Entry flags: KAT - Keep Alive Timer, AA - Assume Alive, PA - Probe Alive
    RA - Really Alive, IA - Inherit Alive, LH - Last Hop
    DSS - Don't Signal Sources,  RR - Register Received
    SR - Sending Registers, SNR - Sending Null Registers
    E - MSDP External, EX - Extranet
    MFA - Mofrr Active, MFP - Mofrr Primary, MFB - Mofrr Backup
    DCC - Don't Check Connected, ME - MDT Encap, MD - MDT Decap
    MT - Crossed Data MDT threshold, MA - Data MDT Assigned
    SAJ - BGP Source Active Joined, SAR - BGP Source Active Received,
    SAS - BGP Source Active Sent, IM - Inband mLDP, X - VxLAN
Interface state: Name, Uptime, Fwd, Info
Interface flags: LI - Local Interest, LD - Local Dissinterest,
    II - Internal Interest, ID - Internal Dissinterest,
    LH - Last Hop, AS - Assert, AB - Admin Boundary, EX - Extranet,
    BGP - BGP C-Multicast Join, BP - BGP Source Active Prune,
    MVS - MVPN Safi Learned, MV6S - MVPN IPv6 Safi Learned
(*,224.0.1.40) DM Up: 5d00h RP: 0.0.0.0
JP: Null(never) RPF: Null,0.0.0.0 Flags: LH DSS
  Bundle-Ether3.802           5d00h     off LI II LH
(10.20.1.253,235.1.0.6)SPT SSM Up: 04:03:32
JP: Join(never) RPF: Bundle-Ether3.802,10.20.1.253* Flags: MT MA
  TmdtIPTV/Bronze             04:03:32  fwd BGP
Thanks!
Hi Viniit,
Yes, some multicast IP like 235.1.0.8 has been up before. But the source is the on the other end And this router was the receiver then.
Is there a way to tear down the auto-tunnel that was created?
Thanks!
mazzy
