06-03-2016 03:46 AM - edited 03-14-2019 04:11 PM
I have UCCX 9.0.2 and I had problem with disk space.
something generates JMX-INFO-jmx.2016-06-03T04-17-25.937 file types.
I know how to delete it but it would be better if 50Mb files doesn't appear each day.
could anybody tell which service generates these type of logs ?
Solved! Go to Solution.
06-03-2016 08:59 AM
And one more thing: I have UCCX and CUIC as separate VMs.
CUIC with UCCX is co-resident. When you say CUIC and UCCX as separate VMs I am assuming that you have a standalone CUIC server as well there along with the co-resident CUIC that comes with UCCx. Also, is the issue regarding the log partition getting full happening on both i.e., UCCX and standalone CUIC or on only one of them.
Also, there is no way that you can disable these JMX log files to get generate unless you completely disable CUIC services (something that I think should work but had never tested myself). They are supposed to generate as a part of CUIC process irrespective of that fact if you have traces enabled or not. The only problem is that they don't get purge on their own as other threads/processes does. There is really not much you can do there in regards to this thing.
Deepak
06-03-2016 08:01 AM
These log files are actually generated by CUIC. In an ideal situation, these JMX log files should be purged automatically by the system so that the Disk partition does not get full. However, due to the below defect it does not happen:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv76430/?referring_site=bugquickviewredir
You might need to check with TAC if they have a fix for this in the form of on ES or maybe they can inform you about the version which has the fix for this.
Deepak
06-03-2016 08:12 AM
Hello, Deepak.
Thank you. Yes, I used exactly this link for getting information how to delete these files.
But I suppose it is some service generating these log files.
So, I wonder how to decrease it level of trace.
Even at CUIC server trace configuration page I can't find what service exactly generates these files.
What do you think ?
06-03-2016 08:59 AM
Deepak
07-24-2016 02:00 PM
Hello, Deepak.
Yes, this is standalong QUIC, but for some reason this logs are filling UCCX disk.
In that case, I guess, I may just manually clear the disk from time to time, since right now I just cannot upgrade the system.
Thank you for respond.
07-24-2016 11:16 PM
Your understanding is correct Fedor, you will need to keep removing the logs manually till the time you do not upgrade your system.
Deepak
