06-05-2016 02:14 AM
I'd love to know, what are the main differences between WAP371 and WAP571?
So far I think it's:
- More powerful CPU for more clients (WAP371 had issues packet capturing for instance)
- 2 LAN ports for > 1Gbps throughput (WAP371 was around 950Mbps because of this).
- Higher throughput on 2.4Ghz (600 Mbps 802.11n vs 450Mbps 802.11n if you can achieve it)
- Spectrum Analyser (helps you spot microwaves, cordless radios etc. that are screwing the WiFi channel throughput).
- 6 more antennas? (or is the Cisco WAP371 data sheet wrong?)
- Better antenna (particularly for 2.4Ggz).
- Better handling for PoE instead of PoE+ (i.e. it won't crash if you try 80Mhz 5GHz on PoE).
- A lot more RAM and flash (256 MB RAM 128 MB flash vs 64 MB RAM 32 MB flash)
Any of these wrong or I am missing?
Matthew
Solved! Go to Solution.
06-24-2016 05:12 PM
I hope you are doing well. Here you have the datasheet for each device so you can compare them.
Now I would like to advise you to contact a cisco SBSC presales representative by calling to 1800-553-6387 so they can give you more details since they are the ones that handled this types of questions
I hope this helps you.
07-12-2016 12:34 PM
Hey there,
The most notable difference between the 371 and 571 is the maximum number of clients that each may have associated with it at a given time. The 371 supports 32 simultaneous client connections while the 571 can support up to 256. Depending on the size of your office space and number of wireless users, you can choose the access point that adequately serves your needs.Let me know if you have any more specific questions.
Best,
-Patrick Ayers
06-24-2016 05:12 PM
07-09-2016 09:34 AM
Hi Jorge,
Thank you for your response.
Those links are in Spanish (and I'm not a Spanish speaker I'm afraid). Also I am not in the US either, but live in the UK.
My employer is a Cisco partner and they were asking me what the difference was between the models too so I raised a case via that.
It really isn't very clear what the differences between WAP371 and WAP571 are from the website and it really should be :-(.
Kind Regards,
Matthew
07-12-2016 12:34 PM
Hey there,
Best,
-Patrick Ayers
08-01-2016 11:18 AM
Thanks Patrick, I have now purchased one.
08-08-2016 08:41 AM
System Memory
WAP371 : 64MB RAM & 32 MB Flash
WAP571 : 256MB RAM & 128MB Flash
Also wireless throughput for WAP571 is far better than 371
WAP 571 - 1.9 Gbps 3x2 MIMO at 5Ghz & 2x2 MIMO at 2.4Ghz
WAP 371 - 950 Mbps 3x2 MIMO at 5Ghz & 2x2 MIMO at 2.4Ghz
371 supports Up to 64 connective users, 30 active users per radio
571 can support Up to 200 connective users, 50 active users per radio
01-16-2018 10:53 AM
01-16-2018 10:48 AM
