06-07-2016 10:53 AM - edited 03-17-2019 06:10 PM
Upgraded to 11.6 on Windows 10 Build 14352 and MS Lifecam stopped working. Reverted to 11.5.4 and it works.
Is there a fix for this?
I have gone through the article about checking logs and can see that the LifeCam does initialize properly in the app so not sure why it will not work. I do get messages about downloading the pictures for contacts allot too.
08-23-2016 06:21 AM
This has since been addressed in newer releases including 11.7. All fixed.
08-26-2016 02:33 AM
We still have this problem. Startet after the last update of Win10.
The are problem With Jabber 11.6 and 11.7. Jabber 11.5 works fine.
Roar
08-26-2016 08:01 AM
I gave the solution to this issue in my other post. Refer the below thread
https://supportforums.cisco.com/discussion/13098351/jabber-windows-does-not-recognize-video-device
Please rate if this helps you.
Cheers
