06-13-2016 05:35 AM - edited 03-19-2019 11:14 AM
Unable to complete CIM&P 11 subscriber node install, below is the error observed
06-13-2016 06:53 AM
Have you added this in cucm publisher as a subscriber?
Is cucm publisher is synced with ntp server ?
Suresh
06-15-2016 07:23 AM
Yes both have been done
06-15-2016 08:23 AM
With this I am assuming that you have disabled the LRO as well as followed the workaround mentioned in defect. If that is correct, then contact TAC so that they can take diagnostic dump failure logs and take it from there
Deepak
06-15-2016 08:53 AM
I was just checking earlier discussion where installation of IMP sub was failing due to DNS reachability
https://supportforums.cisco.com/discussion/12987926/imp-subscriber-installation-fail-reason-cannot-validate-imp-pub
Just have a look else u can approach TAC.
regds,
aman
06-13-2016 10:32 AM
Try disabling the LRO option in the ESXi host configuration followed by ESXi host reboot. Refer below doc for the same and this issue should be fixed then.
https://supportforums.cisco.com/document/95886/disable-lro-ucs-uc-application-deployments
http://docwiki.cisco.com/wiki/Disable_LRO
Take a note of the below defect as well and then perform the workaround mentioned there in case if disabling LRO doesn't help. Though the defect goes only till 10.5(2) but it is still applicable for v11 as well
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur94973/?referring_site=bugquickviewredir
Deepak
