06-16-2016 01:14 AM - edited 03-12-2019 12:53 AM
hello,
I want to activate/install IPS on ASA 5515-x and ASA-5512-x
I'm not able to find what type license must order to activate IPS module
This platform has an ASA 5515 Security Plus license.
Failover cluster licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 100 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Active perpetual
Encryption-DES : Enabled perpetual
Encryption-3DES-AES : Enabled perpetual
Security Contexts : 4 perpetual
GTP/GPRS : Disabled perpetual
AnyConnect Premium Peers : 27 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 250 perpetual
Total VPN Peers : 250 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 4 perpetual
Total UC Proxy Sessions : 4 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
IPS Module : Disabled perpetual
Cluster : Disabled perpetual
ASA-1# sh module
Mod Card Type Model Serial No.
0 ASA 5515-X with SW, 6 GE Data, 1 GE Mgmt, AC ASA5515 FCH18097S02
ips Unknown N/A FCH18097S02
cxsc Unknown N/A FCH18097S02
Mod MAC Address Range Hw Version Fw Version Sw Version
0 7426.acc9.347a to 7426.acc9.3481 1.0 2.1(9)8 9.1(2)
ips 7426.acc9.3478 to 7426.acc9.3478 N/A N/A
cxsc 7426.acc9.3478 to 7426.acc9.3478 N/A N/A
Mod SSM Application Name Status SSM Application Version
ips Unknown No Image Present Not Applicable
cxsc Unknown No Image Present Not Applicable
Mod Status Data Plane Status Compatibility
0 Up Sys Not Applicable
ips Unresponsive Not Applicable
cxsc Unresponsive Not Applicable
Mod License Name License Status Time Remaining
ips IPS Module Disabled perpetual
ASA-1#
Can you help me ?
Solved! Go to Solution.
06-16-2016 11:25 AM
Cisco has offered three types of IPS over the years.
The two that are supported on your ASA software version (classic IPS and CX module) are no longer sold.
The currently offered type is via the FirePOWER service module ("sfr" module type). It is supported since ASA version 9.2(2) and will not show as a module type on earlier versions.
With the sfr module you require licensing and, prior to ASA 9.5(1.5) with FirePOWER 6.0, a separate FirePOWER Management Center to use it.
ASA 9.5(1.5) with ASDM 7.5(1.112) and FirePOWER 6.0 or later allow you to manage the FirePOWER IPS directly from ASDM.
Either way you need to buy a license and install the software module. Here's how to do the latter:
http://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html
06-16-2016 11:25 AM
